Senior Member
So I got a question. The factory metal fuel line that connects to the firewall and runs to the factory fuel rail. Mine is all kinked up and twisted. I want to replace it with just some nylon braided fuel line but I had a question to see if I should use -4 or -6 line. I was going to use -6 just so it will go over all the way over the metal fitting that way I can tighten it down snug but the steelbraided I have used hates to be squeezed. Just wanted to know if anyone has use nylon line and if it would tighten down enough to keep from leaking fuel.
