IMO the best spring to use is the lowest possible, so 3-4 psi depending on the size of your gate. This will allow you to have traction in first on the street and with a 4 port solenoid you can still make 30 psi if you want to.
Yea they are dual 44mm tial MVR wastegates. Possibly be pushing more than 30ps. Might go for .6 spring since I probably won't be lower than 10 psi in first.
Bays coming along nicely there, not much left I see till a startup.
Are you running boost by gear? IF so what psi are you running in first?
