ryaano18
One of the most recent side projects for the build i've been working on, but slacking a little bit with is a cut away center console with battery kill switch mounted in the back. I do plan on using the ktuned shifter and a staging break so the cut away will definitely give me some room to have both. and definitely don't want to hide it. And the kill switch mounted in the back just because i was bored and seemed like a good idea lol
Still in progress, the only thing left is to fill the small dimples, and attach a floor part to the base of the console so you dont see car metal, it will wrap around the contour of the shifter, and probably texture paint it when its all nice and smooth. I'll post more pics when i finish up the work
If i happen to mess this up, which i probably will because i've had to start over on it a couple of times, ill just stick to the type-r console lol
