I was about to say the Same. Have a good night mark.
Seems like a good idea for a thread I'll see what I can do ! and I'm out for the night have a good night Adam
Killer setup
Sent from my SCH-I545 using Tapatalk
If it is hitting boost cut, your injector duty cycle will go to 0 right when it cuts, that's how the cut is done, so look for that in the log. For me using flashpro, boost cut usually is 'slow' to respond in that if the cut is set at 18 psi it will take like 18.5 psi or so to trip it, like it can't keep up completely. IDK if this happens to other people too, but my rev limit doesn't keep up either, like if I do a log for Vit to fuel cut, it will usually get almost as high as 8700 rpm before the fuel cut kicks in. I guess it wasn't designed for the revs to climb as quickly as they do with a turbo
If you guys have the same tables as we do, you can play with your temperature compensation table for boost control, like remove a a couple duty cycle values in the lower temperatures, the table in flashpro works via IAT sensor.
Also lmk what you get to do the boost leak tester, I tried to make one once and it didn't work out as well as I was hoping. I couldn't get a tight seal on the turbo inlet, because the pvc rubber cap I got for 4'' pipes is larger than the turbo 4'' inlet because a pvc pipe is thicker than the turbo inlet metal. Also my turbo has like a hole in its inlet, kind of like exhaust tips have holes for water drainage, but IDK why it's on my turbo.
Well I made the boost leak tester I used all 3" stuff and it fits inside the 4" coupler I have on the front of my turbo perfectly .I will post a few pics shortly .I found 2 leaks right away .
I'd greatly appreciate if you make a thread on this so we can have this archived
