Is PPG still around? All I can find are 5-gear Quaife transmissions for $8000 +
i need to start looking at tranny builds.
Yes they definitely are, and they definitely still make straight cut gears for the k series transmission. In the past they also made semi-helical cut gears (much better for a street car), but as of recent that hasn't been listen on their website. This doesn't mean they don't still offer it, but it isn't advertised![]()
http://www.8thcivic.com/forums/mecha...hain-slap.html
Any advice would be appreciated.
Will they make any gears tho like for instance a higher gear ration like the EP3 thranny for our car instead of the stock gears?
Good info see if i couldnt afford the ppg gears i was just gonna do EP3 1-5 and then the Acura TSX 6th gear. I heard they are stronger then our stock gears.
Yea they used their own ratios. And they also make a 1-2 gears set and a 3-4 gears set as well so you can go in stages of you will. I'm looking to upgrade to a ep3 3-4 and get the ppl 1-2 to help out my 60' times and trap
s4 IG-petefromthestreets now Free
