This was the old kit
So like most I started out with a cold air intake, ran a catless exhaust, then ran a larger exhaust, then bought flashpro, then that was it time to get serious. Like most once you feel power from an upgrade you get addicted to experiment with different tunes different settings to get MOAR POWER.
I dynoed on a Dyno Dynamics and a base flashpro map with CAI, and exhaust but only made 177HP because it was untuned and way rich. Like 11.9:1 LOL that was FAIL! All you have to do is read
So I started learning how to adjust the fuel map with FlashPro and found a lot of other settings that help make more power HA! Imagine that!
After watching YouTube videos of boosted Civics and seeing those RPM's rev to fuel cut faster than I thought was possible... Yeah it was time to BOOST LOL
I started out with a smaller turbo build I pieced together consisting of a top mount log manifold and a small turbo like .63 AR turbine and .60 AR compressor. Modified my stock fuel injectors and started street tuning and ended up with 344HP on the same Dyno Dynamics.
When I couldn't get anymore power from those mods I decided to look at what I needed for more. My friends said "Dude you have a problem" I agreed with them... I don't have enough boost!
I did the whole build myself
(other than the machine work such as boring and honing the cylinders and fitting the oversized valves).
I welded my own intercooler brackets and welded my own 3" stainless exhaust. I tore down and reassembled the whole motor myself in my garage. I surprised myself when it actually started the first time HEHE
And it now has over 4000 miles on the motor
The only way I was able to do this myself was I had the service manual in PDF form for torque specs and reassurance I was putting things back where they go
I pulled the motor out in January 2012 and finished April 27th 2012
Car:
2008 Honda Civic Si 75k miles
Motor:
K20z3
Gauges:
AEM Digital AFR UEGO Gauge
AEM Digital Boost Gauge
ECU:
Hondata FlashPro
Boost Control:
Hondata Boost Control Solenoid
Exhaust:
Custom 3” Exhaust (No CAT)
Custom 3” Downpipe
Custom 1.75” Dumptube
DCSport 3” Muffler
Sidewinder T3 Manifold (I cannot mention the name until I see it fits)
Clutch:
Competition Stage 4 Sprung - Strip Series 1620 Clutch Kit
Competition Flywheel 11LBS 2-800-STU
Valvetrain: Pictures coming soon
Brian Crower Stage 2 NA Cams BC0042-2
Brian Crower Dual spring, steel retainer/seat BC0040S
Brian Crower 7° Billet Keepers / Locks BC2940
Brian Crower 35.5mm Intake (+.5mm head diameter) BC3042
Brian Crower 30.5mm Exhaust (+.5mm head diameter) BC3043
Hybrid Racing K-series Timing Chain Tensioner
Cometic Headgasket 87mm
BottomEnd:
CP Flat Top Pistons w/ ProSeal Ring set CP70456
Cylinders bored and honed
Blueprint H-Beam Forged rods (Hybrid-Racing) BPCRK2001
ACL STD Rods, Main, Thrust bearings
ARP Headstuds 208-4701
Mishimoto oil Cooler kit MMOC-U
Enginetech Gaskets with Fire Seal technology HO2.4CS-A
Fuel System:
Walbro 255LPH-HP Fuel pump
Injector Dynamics ID1000 fuel injectors
K-Tuned Fuel rail with AN6 45 degree fitting and 6ft of AN6 fuel line
Cooling
Mishimoto Radiator (MMRAD-CIV-06si)
Mishimoto Silicone Radiator Hose Kit (MMHOSE-CIV-06) Color Blue
Civic Si Mishimoto Racing Thermostat (MMTS-CIV-06)
Misc Parts:
K-Tuned Upper Coolant Housing (W/Hose Fitting) KUW-24-258
K-Tuned Intake Manifold Heat Shield Gasket KTG-K24-MAN
K-Tuned Idle Air Assist Delete Kit KTD-AA-DEL
GodSpeed 44MM RS-Series Wastegate WG-008
Turbosmart 45mm on standby TS-0506-1002
Treadstone Performance TR12 Intercooler:
• Core Size, 12.5" X 22" X 3.5"
• Supports 700+HP
Treadstone Performance Intercooler piping 2.5”
Injected Front and top torque dampeners
DEI Titanium Exhaust Wrap with LR Technology
Treadstone Performance T3 Turbo Heat Shield
HKS Blow Off Valve
Treadstone Performance Vacuum Distribution block
CX Racing Oil Feed and Return kit Oil-Kit-AN10-7PCS-AN10-S90
Hasport Rear Motor Mount U70A
Ingalls Stiffy Torque Damper
PICTURES
THE NEW:
3.14.2012 Welded brackets for the intercooler out 1/4 inch steel plate IT'S SOLID
It's even
Not feeling the oil cooler
3.20.2012 Block is back
Clearances are good
Hybrid Racing timing chain tensioner and belt came in
Mishimoto Radiator,thermostat and hoses
ASSEMBLY HAS BEGUN
New Lost Motion Springs
Not color coded... work with ya got
Hybrid Timing Chain Tensioner
New wheels
PICTURES
I love this build. Very well documented, great setup. Puts the 8th gens up on the list!! Btw, what fitting did you have to use on the fuel rail to incorporate the OEM fuel line on the feed side? I need to figure it out.
Thank you!
If you're talking about the line up against the firewall I used the factory clip with the hose adapter and all(green clip black hose end and gray cover). The factory fuel line adapter has a barb fitting under the hose. I cut the stock hose off and slid the An6 fuel line over it. I used a fuel injection fuel line clamp to clamp it to the barb. I can post a picture tomorrow.
I am installing a full fuel return system tomorrow. If there wasn't already a how to out there on how to do the fuel return system I would do one.
Sent from my Galaxy Nexus
so the manifold is a PLM rite?
I installed a fuel return system Friday night. It took me 15 hours to install it LOL I don't know why but it did. I also changed my oil HEHE
I was running 10.9:1 AFR between 7krpm and 8200rpm I did not have time to get my fuel map perfect. I was up all night Friday installing fuel return 1pm to 4am. And Saturday I tuned a little bit but did not have time until about 12am I stayed up until 6am doing street pulls. I went to bed at 7am and got back up at 9:30am to head to dyno day.
I love dyno days!! :woowoo:
Here you go. Fuel return line. I actually have -AN6 braided fuel line now. This was fuel injected rubber line I was using as a feed (SAE30R9 is rated to 100psi).
If anyone ever wondered why their fuel line busted it was probably the SAE30R7 which is only rated for 50psi.
