aLmk's 400whp budget build
aLmk
There are some real assholes in this country.
But glad the damage wasn't bad.
Re: aLmk's 400whp budget build
aLmk
Well I cut both ends off of the line that gets pressure to the solenoid in hopes that it had a leak or be seal and that didn't fix this issue so I know it's not leaking out of that line. I don't think it Wouk be leaking out of the line going to the waste gate because if that leaked my logic tells me I'd over boost if anything. Other than those vac lines, the wires of the solenoid being cut and re-soldered in, and the actuator and bracket being taken off and put back on nothing else has changed. Does anyone have any thoughts? So weird that it boosts to about 10psi then completely dies off making less boost than if I turned the boost control off back when things were working correctly.
My apologies, I thought I responded to this. Has it been fixed?
aLmk
I HATE when this happens. Complete BS that makes you wonder how people were raised. Hard to tell full damage from the pic, doesn't look like they got the quarter panel though - which is awesome. What was the extent of the damage? I see a Mugen rear lip coming soon ;)
