IMO the best spring to use is the lowest possible, so 3-4 psi depending on the size of your gate. This will allow you to have traction in first on the street and with a 4 port solenoid you can still make 30 psi if you want to.
Bays coming along nicely there, not much left I see till a startup.
Yea they are dual 44mm tial MVR wastegates. Possibly be pushing more than 30ps. Might go for .6 spring since I probably won't be lower than 10 psi in first.
Are you running boost by gear? IF so what psi are you running in first?
Is the car a track only car? The 4 port can very likely make well above 30 psi, [MENTION=789]VitViper[/MENTION] would know much better the full capabilities.
I am running boost by gear with a 3 psi spring, so in first I hit 3-6 psi by redline (creeping a bit, no boost add in 1st with the boost controller) at the track with slicks I can add boost to first and second, haven't figured out the limit for that yet.
No it will actually probably be more of a street car than track. 550 street 700ish for the track.
Think I might just go with the .5 springs for now which is 7 ish lbs and stay above that for first gear with some sticky tires.
thanks for all the help guys and if you can think of anything else that could help I'd appreciate it.
I would be surprised if you can have traction with that much boost. But if you're not too concerned with that, the 7 psi spring will be fine for everything else, especially if you use a 4 port solenoid.
What does everyone think about having two bungs welded onto my radiator?.? One welded to the top and one welded to the bottom to feed coolant to my turbo? I think this will be the best and easiest way to route the water lines.
Let me know what you think!
I just T'd into my throttle body lines...
Ya. Have you checked out my build yet. ;) everything and almost anything is tucked or shaved so no heater lines.. no tb lines. No nothing besides coolant from radiator to engine and back to radiator. I think it would work great to just have a fitting on top and bottom of mishimoto radiator and then I wouldn't have to worry about waiting for thermostat to open or anything and would always have coolant flowing to the turbo when system is pressurized and might be cooler? Idk.
Just looking for some opinions on it before I commit. Lol
I wouldn't personally I'd leave them hoes open don't run water lines to them.
Setup that is driven for a good amount of time like a street car, yes. To keep temps down.
Setup for drag, not so important due to the short amount of time run. Temps come in fast, so they don't heat up internals to serious levels.
All in all it depends the real use for the turbo and application.
Sorry.
just tap somewhere for coolant. Like that ktuned swivel neck
Ya. I wanted the hoses to be somewhat hidden and not up toward the top of the engine. I might take a look at that tho. If I tap the ktuned coolant neck maybe I could use the original drain from the radiator for the other line?
I have just been slacking too much on my build lately...
Do you have oil cooler lines like on the 8th gen? Could tap there.
But he would want an hoses and fittings, taping there wouldn't work
So. Going to try and attempt to start hooking up my boost oil pressure and aem uego this weekend.. did everyone else have to extend all the plug wires?
I hate wiring.. is it pretty much as easy as hooking all 3 red to positive 12v and blacks to ground then plugging them all in?
Taking baby steps. Anyone have any advice that's has ran these before?...
Spaz maybe...
I don't know about the wires, but use honda bond on any pipe thread involved with those fittings.
Anyone know what size the drain plug thread is for the oem radiator?
No sorry.. Probably 3/8 NPT or something
Thanks to Martin for helping me throw around ideas for cooling the turbo!
http://i1015.photobucket.com/albums/...psccngqrqa.jpg
http://i1015.photobucket.com/albums/...psnuiemzkz.jpg
Whats the front wire harness looked like before I started hacking it up...
http://i1015.photobucket.com/albums/...pshdzivwr4.jpg
http://i1015.photobucket.com/albums/...psgipadgsh.jpg
Got the gauges all wired up!!
http://i1015.photobucket.com/albums/...psixftes3o.jpg
http://i1015.photobucket.com/albums/...ps2lr2i5fz.jpg
http://i1015.photobucket.com/albums/...psexbizd4u.jpg
Now on to some finishing photos. (Just need dump tubes fab'd up)
http://i1015.photobucket.com/albums/...psecpy48pj.jpg
http://i1015.photobucket.com/albums/...ps7hpnsiaq.jpg
Anyone elses intercoolers look funny and somewhat high?
http://i1015.photobucket.com/albums/...pst7qpubeo.jpg
interior....
http://i1015.photobucket.com/albums/...psmz2nvw2f.jpg
http://i1015.photobucket.com/albums/...psz8hhqeyx.jpg
http://i1015.photobucket.com/albums/...psnfymbwpk.jpg
http://i1015.photobucket.com/albums/...psf47f5d6h.jpg
let me know what you think!!
im glad my husband was good help to ya. he pulled his hair brainstorming for ya!
happy boosting
Love it! Especially the dual 044s!
looking so good man!!!
Beautiful build [MENTION=1079]My06_types[/MENTION]! Looking forward to the remainder of the build, as I'm sure you are. I also thought you were [MENTION=30]06_typeS[/MENTION] for a second, as he sold his blue DC5 after he got his NSX.
:welcome::to::boostedk20:
This build is just jaw dropping how nice and clean it is 0_o
Where did you get that hybrid racing throttle body plug? i need one
