Page 32 of 32 FirstFirst ... 2232
Results 311 to 319 of 319
Thread: Spaz is Back and BOOSTED
  1. #311
    ok little update.
    Put the car in the air... and went to town
    Pulled off turbo and found what I expected...
    oil everywhere between head and manifold
    Subframe and trans were next
    switched valve covers to protect my painted one
    Anyone elses wives help pull engines?!
    this oil pool always drove me nuts. Looks like just the sensor in the end...
    Anyone know what this white shit is?!
    I believe it's from the E85
    LONELY ENGINE BAY
    started disassembling my engine. Removed intake manifold
    Got timing tensioner set
    number one thing to remember is label everything!! I use lots of ziploc bags!
    box full of bags labeled for every nut and bolt
    removed all the front pieces (starter, water pump, alternator etc.)
    laid out parts on table
    double nutted the water housing bolts off
    pried off timing cover
    now time for the head
    removed all the bolts holding cam caps
    removed cam caps and cams (kept them in order)
    ziptied all the rockers
    removed it
    loosed all of the head bolts next
    pulled the head off
    Found this little guy... not sure what it is.?!
    was found here..
    pistons look decent
    cylinders look good.. tops are dirty which is to be expected
    that little thing is a water/coolant diverter.
  5. #315
    So I'm looking to go around 10.5:1 compression what are your guys thoughts?
    That's a good ratio. A lot of ppl are running that or 11:1
  7. #317
    10.5 sounds good. Minimal difference between that and 11. What plugs will you be running?
    Just want to say that it's awesome you're so organized with your tear down. Takes experience to get that stuff down!
  8. #318
    Dude, SO organized. I need to do this on my next build.
  9. #319
    Long time no see... the car has been down for almost 2 years due to some bent valves... but she will be back up this season
