Page 42 of 42 FirstFirst ... 3242
Results 411 to 420 of 420
Thread: 05 RSX Type S Rotrex Project
  1. #411
    Senior Member SAX JONZ's Avatar
    Feb 2013
    Holy shit man. That happened to me on a junk mustang I owned. Hood cracked and latch came up as I went to pull over it immediately let loose and flew up at 55. Didn't do that much damage though. Scary as hell. Had there been traffic may have been scary. Sorry to hear of that news.
  2. #412
    Feb 2013
    Ok, so I went to the dealership yesterday and looked on their parts fiche. No mention of that rubber gasket for the front top hat. Just the rear. Doesn't make any sense because those top hats come with the gasket installed already.
  3. #413
    Quote Originally Posted by SAX JONZ View Post
    Odd.. keep us updated.
  4. #414
    Feb 2013
    No one here has taken apart an 02-04 front top hat before that can chime in?
  5. #415
    Feb 2013
    I just talked to a friend who still has his old suspension. I will find out shortly. I know that most suspensions come with their own. My friend was just asking why I didn't buy camber top hats 🤓. I guess I like the way things are functional.
  6. #416
    I like my camber hats. lol.
  7. #417
    Feb 2013
    I should have thought before I bought but hey, it's all good. Not going to be running anything other than track time improving camber. I think I can dial a bit in from the bottom. I'm surprised no one commented on this question that has 02-04. Guess I'll be the first so that no others have the same newb question as I have. I mean, I would have known if I had the 02-04. All good. I never knew stage 4 was good for 10-20k that sucks. 🤓
  8. #418
    Stage 4 good for 10-20k miles? As for the camber hats thought, itt never even crossed my mind! I didn't know they were a separate entity. Once all is figured out, please create a thread so others who may have this issue can see it for the future!
  9. #419
    Feb 2013
    Will do. It appears that the kit kseriesparts sells lists those as the parts needed. The rear top hats have their own installed OEM. Through me for a loop. I am just still a newb to many things but learning curve is going up. The recommended setup for the kw variant suspensions is OEM. I guess I could dial in a little camber up front from the bottom bolt as the bolts look like the rear toe bolts. I went with the KW's as they were stainless and do not need to be revalved every 16 months or whatever the normal interval is for coil overs. I will post up a thread as soon as I get a chance with the install.
  10. #420
    It's always a learning curve, that's a part of the fun! Good info. I didn't know about revalving intervals on coilovers.
    Looking forward to that thread!!
