Page 17 of 32 FirstFirst ... 71727 ... LastLast
Results 161 to 170 of 315
Thread: Supercharged CHAT Thread
  1. #161
    Senior Member bluEP3_SC's Avatar
    Aug 2013
    NY / NJ
    Quote Originally Posted by beppe View Post
    9psi max without cooler be safe?
    should have asked disadvantages of changing to larger crank than smaller sc pulley?
    9psi is pretty much the limit without cooling. You should be ok but i would keep an eye on your IATs
  2. #162
    Quote Originally Posted by bluEP3_SC View Post
    Thats a diff story then. Depending on your pulley setup and vtec crossover point- 9 psi sounds normal. Mine will peg 12ish before the crossover around 3600rpm.
    You make 12 psi at 3600?! Doesn't it build linearly from there to redline?
  3. #163
    Aug 2013
    NY / NJ
    Yes its linear- but it makes boost a lot quicker on the low cam before the crossover due to back pressure in the cylinder head ( smaller cam lobe= not as much flow)- once it crosses to the high cam boost drops 2-3 psi then continues to build linearly until redline.
  4. #164
    I never knew that. Great post
    Junior Member bulliedog's Avatar
    Aug 2012
    Maryland
    Check what your blower rpm's are. I ran 10 psi for a year or so before adding cooling. My set up it was 5.46(CP)/3(BP0x8600(RPM)=15,652 rpm's. On hot days you want to be smart and not do multiple pulls in a row but it is easily done. I ran at the 1/4 mile track and DD'd the car. Every set up will very buy set up do to air flow/exhaust flow. Allowing air more available to the blower is really beneficial as well. Like bigger inlets and bigger TB's.
  6. #166
    What is your boost at redline?! I'm thinking you're at 12 psi that early on you must be at 20 psi? By redline?
  7. #167
    Aug 2013
    NY / NJ
    I max out at 14ish psi at 7800 rpm. At the crossover it drops to around 8-9 psi then it builds linearly from there. Its a positive displacement blower so boost is going to depend on the engines flow characteristics.
  8. #168
    Dec 2013
    anyone help with belt size, removed aircon and rsx/ep3 crank mercracing bracket, 3.2in pulley thanks in advance.
    bought a 62in was too big
    measured it with string 56in
  9. #169
    [MENTION=287]bulliedog[/MENTION] [MENTION=974]MercRacing[/MENTION]
    Aug 2012
    Maryland
    Take the 62" back and tell them you need a 56" if that is what you measured it at. They can use the belt number to find the belt in the size you need. I take it that this is a RSX or a swap car?
