Page 68 of 88 FirstFirst ... 18586878 ... LastLast
Results 671 to 680 of 871
Thread: aLmk's Turbo FA5
  1. #671
    [MENTION=40]monjarassi[/MENTION] that worked perfect! Thanks
  2. #672
    Great.
  3. #673
    How much ultra torque should I put on the head studs [MENTION=83]vdubkilla[/MENTION]
  4. #674
    Not to much just coat the washer a little , the bottom of the nut with a little and a little on the threads as well .I wipe off any excess usually after I torque them .
  5. #675
    Ok thanks, should I not put the lube on the threads of the stud that go into the block?
  6. #676
    I always use a little on those threads as well but remember only thread the studs into the block hand tight .
  7. #677
    Ok great thanks! Had me concerned for a second because I put some of the lube on those threads and hand threaded the studs into the block already. Thanks for reassuring me. What torque do you suggest? I was planning to do 90 ft/lbs in steps of course.
  8. #678
    I went 90ft lb as well
  9. #679
    I did 95 on mine for that xtra pc of mind.
  10. #680
    All for now
