				great build thread love the numbers it made.. you guys in the states know your stuff..
i need to do that fuel return line as when mines quarter tank its splutters cant get enough fuel
Thanks guys- i just had her detailed yesterday... First time she has seen wax in 10 yrs lol. Need to do brake pads today- its always something
Regarding your fuel issue- id pull the in-tank fuel cage and inspect. You shouldn't be getting sputtering at less than half a tank unless a filter is clogged or you have an obstruction in the line. I only went with a return so i could run e85
				No worries man- you should try to hook up a fuel pressure gauge at the rail when your tank is that low- just to see what your fuel pressure is like. You also might have a leaking return hose in the tank, which goes from your fuel pump outlet to your intank pressure regulator then back to the suction side of your fuel pump. Id try the fuel pressure gauge first though- then work from there
Cleaned the bay up a bit
				Looking great!
