Sunroof delete, I located some fiberglass doors already fitted and made I'm thinking of buying. Gut the interior, remove the tar, cistom chromoly steering rack, a chromoly bar to replace the one going across that's under the dash...and last but not least lose weight!
Fuel system king crew member #1
i removed the tar in the trunk and by the fuel pump, saved maybe 3 lbs of weight lol
ive been having good luck in the wiring though. Can't describe how much wire is able to come out and it adds up in weight! about to start working on the the floor harness to remove all srs and and seat wiring from it and see how much that adds up
This was from the fusebox harness alone. I did the same to the dash harness and it was about half this in scrap wire
