ive been busy last week installing k20a2 swap into the gfs new SIR coupe.
I removed my clutch to put in hers and well, shes toast. I kindve figured it was slipping at the track
Removed the k swap from the hatch to put in the coupe
then i got bored, so decided to test fit my turbo and manifold.
I ran into a small problem. Using the z1 head, the coolant ports on the back arent the same as a A2 head. There fore, my bottom wastegate runs right into the coolant thing on the side of the head. I called Mike at ktuned, and he thinks their side adapter will help clear. If it doesnt, i dont know what else to do beside running no heat
