What are you going to change to get to 600? are you building everything or just going to run race gas? your thread title seems strangely familiar to me LOL
Good luck with the build.
I've been on the forum for a bit just have not posted a whole lot... I went 10 months on my boost Junkyz kit and stock motor and made 462/300 on 15psi . We are now in the process of doing a sidewinder kit with a comp ct4-6062 an see what kind of power it will make. Ill be running on a stock block and pump gas for the time being , but building my spare motor for big numbers. Ill post a few pictures of the car and I will try to post more as the build progresses but I'm pretty busy right now so stick with me.
List of mods
-one off Boost Junkyz front mount 2 piece turbo manifold
-Boost Junkyz 3" 2 piece downpipe
-Boost Junkyz vertical flow same side intercooler
-Boost Junkyz wrinkle black powdercoated charge piping
Boost Junkyz catch can/ coolant reservoir
-Comp Turbo ct4-6062 triplex ceramic ball bearing turbo
-2 Tial Mvs 38mm wastegates Black
-Tial Q black blow off valve
- [MENTION=789]VitViper[/MENTION] 4 port boost control solenoid
-aluminum v-band charge piping couplers
-Boost Junkyz hand port and polished intake manifold powdercoated wrinkle black
-tsx hand ported and polished throttle body powdercoated wrinkle black
-Injector Dynamics 1000cc injectors
-Karcepts black fuel rail
-Hondata 4 bar map sensor
-Full-race 3" cat back exhaust full v-band
-Aem digital wideband and boost gauges
-xlr8 dual gauge pod
-Hondata flashpro
-Hondata traction control
- [MENTION=789]VitViper[/MENTION] tuned
-custom powdercoated vented valve cover
-all vacuum lines , catch can lines, fuel lines in black AN fittings and black SS nylon lines
-Walbro 255lph fuel pump
-varrstoen es 2.2.0 17x9+30 wheels on 245/40/17 Bridgestone tires
-Varrstoen neo chrome open ended lug nuts
-skunk2 coilovers
-skunk2 v2 rear camber arms
-pink beaks rear lower tie bar w/ BOOSTED BITCHES sticker
-Hybrid racing full replacement short shifter
-hybrid racing cable bushings
-mtec shift spring
-competition clutch stage 4 clutch
-hasport full replacement mounts
-09 front end conversion
-s2000 push button start
-dual projector retrofit headlights
This should be a fun build !
How the garage looks now getting the kit ready to ship out
I'm gonna miss this manifold we had lots of good time together lol
Too much shit in here
Yeah I'm building the motor , wiseco 11:1 compression , Manley turbo tuff rods and yeah ill run dual maps, one on pump and one on race gas. The car is still going to be my WIFE'S daily lol. I guess I should state it's a mainly female driven car. She drives it to work everyday .
Sub'd. Good luck! Are you going to sleeve the block?
So the one you're building with 11:1 pistons will be stock sleeves?
