E-Tunez
No problem, we don't usually give freebies, but seeing we havn't done anything for BoostedK20 for awhile, this one is on the house. Its just a basemap of course, so will require more work for sure. Had tuned one of these on the rollers last year, near identical build so should be close, reset some parameters for safety. Recommend 4 bar sensor, be sure to calibrate TPS. As always, all maps are for offroad use only, there are no mechanical guarantees, please review parameters before uploading, please check our site for the legal disclaimer, etc.
Etunez custom tune for: Boosted K20
Type: Offroad use only.
Car: K20 PRB
Modifications:
SD Based intake
5858 Turbo
ID 1000cc injectors, standard latency.
Assumed 48psi +/- 5psi fuel pressure assumed.
Free flowing Exhaust
Fuel: 93 Octane 10%E assumed.
Elevation: 500ft ASL assumed.
Rev1: Custom fueling, ignition and VTC for a PRB K20 turbo build, Assumed stock MAP sensor, recommend 4 bar.
