i know this is old, but im venturing down this road now. I want to add some spacers to my wheels to bring them out some.
did you do anything yet Joe?
I'm thinking that I'll just keep my wheels but add some spacers. Stock 7 inch wheel and the offset is +45, I'm thinking of running 15-25mm spacer bringing my offset to +30-20.
Noww my question is will the spacers interfere with suspension settings? Also what recommendations do you guys have for tire size. What is the best or widest sizzled tire for a 7 inch rim? 235-225 x 45/17.
Also let me know if any are for sale.
Any help is appreciated.
Joe
1991 Acura NSX
When I had stock rims (17x7" +4?) I rocked a 25mm spacer and loved it. If I had to do it again though I'd look for a plus 20mm cause it was a little wide if I wanted to go lower.
I have a set of 8mm spacers on right now. Looks better then stock. I was debating on p[utting on another 8mm sopacer but Brent said its not good to run two spacers ....
Joe
1991 Acura NSX
When I run my OEM Si wheels for my winter setup, I run 10mm spacers all around and it looks awesome lowered on coils and wouldn't rub at all. Now, i'm running 17x9 +42 grids with 245/40 tires, 5mm spacers in the rear. I'm rolled all around and I'm rubbing on hard turns and some bumps on the bumper/quarter panel screw in the wheel well. All depends on your wheel specs.
And 06_typeS don't run two spacers. Just like condoms - Just run one with the right specs You can get em cheap on ebay (spacers).
where did you pick up the spacers joe?
MSG Brent on msc. he has extras.
Joe
1991 Acura NSX
