dat turbo filter
man that turbo kit is crammed in there!
dat turbo filter
Yess it is!! had to put the manifold and turbo in as one whole piece
Thank you sir!
Yeah its massive, it was my 3" blox vstack, i now have a 2.5 vstack but its still massive, once i get an intake on it, ill be good
Alright!!!
So I got the car all finished so here’s update of how it went down!
Well I pulled everything apart (PITA ball joints)
Then I took the knuckles and lca’s to the guys at 757 Automotive Specialists. Guys do great work; the best part is their customer service. They’re a small shop but they let you know exactly what is going on with your parts. Good people. On to the new parts!
LCAs
Blox Spherical Bearings
Energy Suspension Bushings
Knuckles
ARP Extended Studs
Buddy Club Extended Ball Joints
New Wheel Bearings
I decided to switch out my koni shocks because they were blown beyond belief
Pulled everything apart, good thing about the koni cartridges is you don’t have to take the tie rod ends loose
New shock and sleeve cleaned and installed
All reassembled!!!!
Drivers
Passenger
I’m also running Gorilla Lugs Open ended lugs!!
Hope everyone likes!!! :thumbsup:
good stuff, been there done that, i know dat feel
Sooooooooo, I jacked her up again today and made sure all the bolts were nice and tight. Also I re-greased my lca bushing.
There was a little clearance issue between the ball joint and the brake dust shield so I took some shears to the cover and cut off a small piece for clearance.
Last, I balanced out the rear coilovers so the car is sitting pretty for now.
I didn’t take a whole bunch of pics on this one lol, but if anyone has a question, ask away and I’ll answer it
Heres a pic of my lugs on my arp ext studs:
Pic of me cruising up to Walmart (returning the wipers for my 2010 civic sedan )
I got bored at work because im working 3rd shift (11pm to 7am)
But all sanity was not lost, I managed to throw together a schematic of my battery relocation and fuel return setup (idk when its gonna happen), I decide im gonna use a BRAILLE B3121 battery!
LMK what you think!
shouldnt be long for ryan to chime in
that's gonna ride real nice with all the new suspension everything.
