Results 1 to 10 of 22
Thread: Post your Dyno sheet / plot or plots
    NEVERMIND!!!!
    I see what's happening here. The chart you posted, and the second chart I posted is a guide to tell you how to get desired boost levels. For example, if you look at the .5 bar section of your chart, it has both the green and red spring. What this is saying is you need both of those springs in the gate to make .5 bar be your opening pressure. The chart's lowest single spring it lists is in fact NOT the smallest spring available from tial. This make sense? If you want the smallest possible you want to use just the small green spring which is .2 bar for the MVR and ~2.9 psi.
    I called ATP Turbo to order mine and thats what they told me was the lowest spring pressure the make for the MVR s a 4.3
    Well they were mistaken:
    http://tialsport.com/documents/MVSprings2.jpg
    Look at the far right spring.
    hey what does ATP know please Post your Dyno Plot
    Bump let see some more dyno s any kind e dynos or other
