Page 2 of 2 FirstFirst ... 2
Results 11 to 17 of 17
Thread: Oil feed suggestions
  1. #11
    Mar 2013
    Bowling green ky
    I'd have to look closer at that is the oil sandwich plate is tight to the block ? The filter it isn't double gasketed is it ? Meaning an old gasket was stuck on there from an old filter when the new filter was installed or did the new filter have a good gasket ? Have you tried another filter ? I haven't really had any issues for the most part with mine its made by Golden Eagle .If yours is leaking it's pretty well gotta be a gasket issue one one of the sides of the oil sandwich plate or it isn't tight as it shouldn't leak massive amounts of oil . Who makes the plate your using out of curiosity ?
    Which golden eagle one did you get? I'm just guna go that route
  2. #12
    Mar 2013
    Bowling green ky
    Like are they vehicle specific or universal? I'm seeing ones that say lsvtec
  3. #13
    Quote Originally Posted by Lilwhit14 View Post
    Its been a while since I bought mine but I believe it was this one as it has 2 ports http://www.nolimitmotorsport.com/prod/GEM-GVC100-P that way you have one port for the turbo feed and the other for an oil pressure gauge .
  4. #14
    Mar 2013
    Bowling green ky
    The only I'm seeing when searching golden eagle are the lsvtec ones. Do you have a part number or a website you got yours from? I'm just tired of leaking oil. It's caused me to have to replace my wiring harness bc oil is just everywhere and I think that's why my car is throwing an ecu failure code
  5. #15
    The link I posted shows ya the one you need to get if you read the description it tells you that it has 2 oil ports one for a clean filtered connection for the turbo oil feed .Just ask them to be sure when ya order it but I'm pretty certain that's is the correct one .
  6. #16
    Mar 2013
    Bowling green ky
    Ok. And I'm assuming it works the same way, oil filter screws in to that as well. I appreciate it. Hopefully this fixes everything after the new wiring harness
  7. #17
    Mar 2013
    Bowling green ky
    I got the bwr one off eBay. Don't know why it's not working. I'll order some extra I rings with it. Thanks.
