Page 2 of 2 FirstFirst ... 2
Results 11 to 19 of 19
Thread: Plastic Cowl modifications?
Hybrid View
    Senior Member vdubkilla's Avatar
    I also had heat issues on my EG and have deformed 2 wiper cowlings now .I had my turbo manifold and dump tubes and down pipe ceramic coated and heat wrapped all of them it has really helped with heat in the bay though it still gets hot its not anywhere near as bad as it was .I have also heard the possibilities of manifolds cracking ect but the heat was imo more dangerous than not doing anything .Heat wrap your manifold ,dumptube, downpipe ,ect.. install turbo blanket ,and wrap as much as you can with heat shield it helps .I am also gonna look into that stuff that goes on the fire wall to protect the firewall / inside of the car from getting warm after a big pull .Its not as big of a deal in the winter as it's my source of heat haha but dam it aint much fun when its 90 degrees out
  4. #2
    Junior Member 1JZ_Type-S's Avatar
    Oct 2013
    Quote Originally Posted by vdubkilla View Post
    I also had heat issues on my EG and have deformed 2 wiper cowlings now .I had my turbo manifold and dump tubes and down pipe ceramic coated and heat wrapped all of them it has really helped with heat in the bay though it still gets hot its not anywhere near as bad as it was .I have also heard the possibilities of manifolds cracking ect but the heat was imo more dangerous than not doing anything .Heat wrap your dump tube , install turbo blanket ,and wrap as much as you can with heat shield it helps .I am also gonna look into that stuff that goes on the fire wall to protect the firewall / inside of the car from getting warm after a big pull .Its not as big of a deal in the winter as it's my source of heat haha but dam it aint much fun when its 90 degrees out
    Lol @ your "heater". I'm in the same boat. The colder it is, the more I boost. Lol
  5. #3
    Quote Originally Posted by 1JZ_Type-S View Post
    I actually wish I had never deleted my heat and may re install it this winter as I still have everything .The turbo manifold does work though just mash it a few times with windows up and the car warms up pretty nicely inside haha
  6. #4
    Oct 2013
    Haha. I'd have changeable temp settings, but the little mount that holds the wire in place, broke. So I need to ziptie that thing to keep it from moving
  7. #5
    BoostedK20.com Founder
    BoostedK20's Avatar
    The only thing that comes to mind is the Gruppe M intake that people were crazy about 4-5 years ago. It's a 'Ram Air' intake that also takes air from the engine bay. I wouldn't buy this, but this may help you move forward in your search.
    If you're good with molding, carbon fiber holds heat very well. Your imagination is your limit.
    Need parts for your k-series setup? Check out our eShop! Click Here
    For all your eShop support needs:BoostedK20.com eShop Support Forum
  8. #6
    Boostaholic
    monjarassi's Avatar
    Houston TX
    2 (100%)
    i must say my wiper cowl held up the duration of the time i had the dumptube out the wiper hole, pipe was un coated and shot a couple flames here n there.
    Not to mention my cowl is plastidipped black.
  9. #7
    NSFW Specialist MajorWeak's Avatar
    Oct 2013
    360 Washington
    I was having some problems with heat as well. I recently wrapped all the wires, hoses, and throttle cable in the area. I wrapped my downpipe with exhaust wrap and noticed a huge difference. Since i have a top mount shitty long mani there is a ton of heat still. So, I cut a slot in the cowl to release heat quicker. At stop lights i notice the waves of heat escaping. The other side isn't done but this is what im working with now.
    Daily Tuned At 261hp 193tq @ 5psi
    ~Functional Crew~
    NSFW VIP Thread
    20 Pages and Counting!
    Not a VIP? Become One Here
  10. #8
    Super Moderator
    Spaz's Avatar
    Instead of wrapping your parts send them out for JetHot Coating. Then wrap your wiring and such.
    Junior Member echo3gulf's Avatar
    Oct 2012
    From Ohio but currently stationed in North Carolina
