Page 3 of 4 FirstFirst ... 3 ... LastLast
Results 21 to 30 of 35
Thread: Need trans help!!!!!
  1. #21
    Newbie froggyfredd's Avatar
    Oct 2012
    columbia south carolina
    36
    That makes me feel great!! Glad I got them lol I like them sofar but only 100 miles on them
  2. #22
    Enola, PA
    Quote Originally Posted by VitViper View Post
    OEM syncros 4tw. THey may not all be fancy carbon coated and such -- but at least the splines don't disintegrate after 20 miles.
    ^yeahthat
    thanks for the input!!! Means alot
    A bit late on this one, but I totally agree with Vit, I got the synchrotech carbon syncros brand new from synchrotech directly around September 2012. They had an update before then on them that's why the date is important. I was revving to 8800 at the time. And they were no better than OEM, in fact I thought they were worse.
    The issues with our cars transmission isn't the synchros. its typically a CMC adjustment issue, but once you grind a gear a few times you ruin the engagment teeth on both the gear and the sleeve itself. Once this happens nothing will fix it short of replacing the gear.
  3. #23
    Wow that sucks that kinda ruins my plans
  4. #24
    What were your plans? Why not just use OEM synchros?
  5. #25
    Ok well here were the plans:
    Cryo-treat the gears
    Replace syncros(OEM/syncrotech)
    MTEC race spring
    I have a bud from Louisiana thats been using this similar in his kswap 5spd tranny and every yr he upgrades the motor or anything to add more power the dam tranny is still holding up!!
    We talking a bout a 600-750hp kswap tuned on BBG and running full slicks on the streets.
    Thats why i dont get why many ppl have had bad experience with the Synchrotech syncros
  6. #26
    MTEC race spring
    Not sure how it ruined your plans though? You can use the stock synchros... Or you can use the synchrotech ones... Also have you heard of Racer Steve on honda-tech? He treats gear and has had quite a success rate. I got some gears treated by him, but haven't put them in yet.
  7. #27
    Ill look him up and see what i can work out i had found a shop in Florida that does them but only on the weekends or sum like that
  8. #28
    Gotcha, his treatment is $200 with the good reviews I figured I'd give it a shot. You just send him the gears all broken down and the shafts too.
  9. #29
    yea thats very affordable.. I wouldnt mind given a shot, its worth a try
  10. #30
    His username on honda tech is racerstev
