Time for an upgraded build... some may know, my built motor skipped time, destroying pretty much every valve. So now I'm building my spare block for the 08 Si.
- ERL is building the block: sleeved, 1/2" head studs and O-ringed (fuck you head lift... we're not that good of friends).
- 88mm bore (2.1L) K20Z3
- 11.0:1 c/r JE pistons
- Manley Turbo Tuff rods
- ERL S2000 Oil pump
- Portflow K20Z3 head w/ standard size Supertech valves
- Custom Jeff cams (used to be GO Power, now @ Skunk2). Something like 14.2mm lift intake & 14.2mm lift exhaust, exact specs I will never share (heh...)
- Comp CT43-6767 turbo (upgrading my 6465 into a 6767, 700-800 wasn't enough apparently)
Oh yeah... ERL S2k pump on a Z3 block w/ Z3 oil pan...
Stay tuned for more!
