I'm running 10lbs. The highest you can go is 11. If you go over that you will over spin the bearings in the rotrex. So, I'd keep it at 10 at the highest.
				Thinking of uping my boost on my Kraftwerks kit with stock internals. Just want to see what other people are running at?
				Np, [MENTION=56]Adm_rsx[/MENTION] should have more input on this, too. What kinda car is the KW Kit in?
				2008 Honda Civic SI
Ya unfortunately with that kit you are kinda stuck at that boost level and those power levels. Only option I'm aware of is to get a larger blower, but I'm not sure if you can use a larger blower with that kit.
Yea unfortunately the c30-94 doesn't produce much boost. Without an intercooler someone made 18psi but remember more boost isn't everything.
				i'm close to 12 lbs.
We need to create a 'Kraftwerks Modification' list to see what can be done for this kit.
