Hit the track today. Started out slow on the boost, trying to keep the tranny alive. 6 passes and we started with 119mph up to 148mph @ 27psi in 4th (bbg, less boost in other gears). I got him to turn the boost up all over and put 34psi in 4th, along with preaching "power shift" so doesnt loose time between shifts. Well boost worked, but powetshifting did not. Sheared the teeth off second gear.
Final run @ 27psi 10.32@148mph. More work on the half track and its into the 9s.
Bascially hes done for this year, as he has other cars to finish up, so we'll just wait for the dogbox to arrive and pro axles(and 3 piece, cc wing, difusser, and parachute)
Last pass before second gear blow
Last minute headlight intake set up. We didnt know if it would work, but it does. A velocity stack will be modifed into the housing
https://www.facebook.com/photo.php?v...0¬if_t=like
