Page 16 of 25 FirstFirst ... 616 ... LastLast
Results 151 to 160 of 247
Thread: Blown Big Block EP
  1. #151
    Senior Member bluEP3_SC's Avatar
    Aug 2013
    NY / NJ
    o shit we have tha same laptop
    Sony vaio? I need a new one- keeps freezing when im data logging
  2. #152
    Quote Originally Posted by bluEP3_SC View Post
    yess sirre
  3. #153
    Lmao that's you're only comment out of all those pics
    [MENTION=954]bluEP3_SC[/MENTION] looks great!! She sure looks beautiful, show car or not. Everything fits together well!
    Dec 2013
    great build thread love the numbers it made.. you guys in the states know your stuff..
    i need to do that fuel return line as when mines quarter tank its splutters cant get enough fuel
  5. #155
    Aug 2013
    NY / NJ
    Thanks guys- i just had her detailed yesterday... First time she has seen wax in 10 yrs lol. Need to do brake pads today- its always something
  6. #156
    Aug 2013
    NY / NJ
    Quote Originally Posted by beppe View Post
    Regarding your fuel issue- id pull the in-tank fuel cage and inspect. You shouldn't be getting sputtering at less than half a tank unless a filter is clogged or you have an obstruction in the line. I only went with a return so i could run e85
  7. #157
    Dec 2013
    think filter is has been changed recently only happens at full throttle, when fuel is lowish.. we have 99 octane here soon will have 103, thanks buddy for advice
  8. #158
    Aug 2013
    NY / NJ
    No worries man- you should try to hook up a fuel pressure gauge at the rail when your tank is that low- just to see what your fuel pressure is like. You also might have a leaking return hose in the tank, which goes from your fuel pump outlet to your intank pressure regulator then back to the suction side of your fuel pump. Id try the fuel pressure gauge first though- then work from there
  9. #159
    Aug 2013
    NY / NJ
    Cleaned the bay up a bit
  10. #160
    BoostedK20 Sponsor
    Oct 2013
    NY
    Looking great!
