Quote Originally Posted by bluEP3_SC View Post
It bounces between 2k and 1k rpm. When i try to slowly bring the rpm up the motor blips then stumbles then goes back to bouncing. The issue started when i had to replace the battery about 2 months ago- i thought it was an idle relearn but i cant keep the rpm above 3k consistently.
Sounds like the tps like you thought. I had a wire lose connection on mine once. Had to run a new wire and it was fixed. So I'd also check power at both ends to make sure they are conductive.
