Page 29 of 32 FirstFirst ... 1929 ... LastLast
Results 281 to 290 of 319
Thread: Spaz is Back and BOOSTED
  1. #281
    The ID injectors I bought used have an extra SN hand engraved into the injectors and when I had them cleaned and flow tested by ID they didn't tell me they were fake. Do yours have the extra SN?
    I'll have to look. I bought mine used as well off crsx.
  2. #282
    So here is my newest update. I teamed up with Josh at Annoited Aero and got my hands on the new Mugen 330mm risers.
    I took some comparison photos
    The bitch of this process was getting my old stands off... Because it's an authentic Mugen wing I used the double sided gasket that came with it so with fishing line, googone and a putty knife I spent a good 2 hours trying to get the stands off...
    But then I put the ball and chain to work to clean off all the left over adhesives
    Then I used some rubber gasket roll I had and created two new gaskets. They won't be sticky but they will work just fine
    And now install and enjoy!
    haven't even had a chance to look at the photos I took from IA but man I've found some awesome ones online. These I just found from InitialDougie so I thought I would post them on my show-off. Thanks man!
    Is the gasket just to prevent scratching the brackets?
    Looking good! How'd the AC unit work out?
  5. #285
    Senior Member 02civic629's Avatar
    Mar 2014
    VA
    This ^^^^ lol
  6. #286
    yeah... so in the garage testing it worked fine... in the real world the fan was just not powerful enough and it didn't do shit... I need a much much more powerful fan.
    And yes the gasket is just to help cushion/protect and keep water out of the screw holes going into the side pieces I assume.
    Well... she's back in pieces... blew up another transmission.. and while I'm at it I'll see if I can find this oil leak.. but I'm pretty sure it's a valve guide :emo:
    Had to pull this god damn piece of shit out yet again
    To start dropped the subframe of course
    pulled the turbo kit
    here's my mess
    how my engine bay sits
    Found oil around the manifold
    but also oil around the turbo
    Took transmission to my buddy Calvin and we opened it up
    found some teeth lol
    found where they were from
    Now to wait for new parts to arrive
    make sure u drain the gas if the cars gonna be sitting and the inj.
  9. #289
    Looks like the oil leak could be the turbo.
  10. #290
    but wouldnt explain the oil around the manifold doh
