also put the turbo back together and started reinstalling will post photos tomorrow
Got a chance to start working on my car this weekend. Installed the new coated manifold
decided to put the turbo back together
bolted it up lightly
Mocked it up to clock the turbo
Very excited to be able to put my sway bar back on this season! Rewelded a new bung on the downpipe to clear O2 sensor from sway bar.
This is a support bar that I just used a big hammer to to clear room for my dumptube which was touching
now there's plenty of clearance
Buddy Dillon took some photos too and helped me out
We started out the day by fixing an oil leak that Zack chased down to a "Christmas tree" of plumbing tees for his AEM oil pressure sending unit, OEM sending unit, and turbo feed line. Here's where we started:
Good idea of where the leak was at:
So I wrapped some "heavy duty" teflon tape around a brass elbow fitting and put it back into the tee as tightly as possible.
To allow the elbow to connect to the AEM Sending Unit I had to grind down the tee's backside:
Voila
Got under the car and went Santa on this b*tch...puttin' Christmas trees up in this b*tch..
Some other odds n' ends we took care of include a new throttle cable which you can see Spaz cutting metal crimps off of here:
Re-tucking and fixing a leak on a PVC line:
Clamping up the DP:
Getting the O2 sensors in:
Mocking up the turbo with the painted cold side and ceramic-coated hot side:
And making the sway bar fit with the DP:
The man and the masterpiece...
:thumbsup:
I be standing like that too!!
I stood there for a good 10 minutes wondering where or what to work on next... what can I do to make it look better... etc
Had no idea he took a photo lol
^hahahahahahahaha
