Page 31 of 32 FirstFirst ... 2131 ... LastLast
Results 301 to 310 of 319
Thread: Spaz is Back and BOOSTED
Hybrid View
    Senior Member 02civic629's Avatar
    Mar 2014
    VA
    Have you ever sent your manifolds out to be flow tested?
  4. #2
    Super Moderator
    Spaz's Avatar
    Quote Originally Posted by 02civic629 View Post
    No but I would love to one of these times. I should buy one for myself and do it for that reason
    Super Moderator
    Spaz's Avatar
    started disassembling my engine. Removed intake manifold
    Got timing tensioner set
    number one thing to remember is label everything!! I use lots of ziploc bags!
    box full of bags labeled for every nut and bolt
    removed all the front pieces (starter, water pump, alternator etc.)
    laid out parts on table
    double nutted the water housing bolts off
    pried off timing cover
    Super Moderator
    Spaz's Avatar
    now time for the head
    removed all the bolts holding cam caps
    removed cam caps and cams (kept them in order)
    ziptied all the rockers
    removed it
    loosed all of the head bolts next
    pulled the head off
    Found this little guy... not sure what it is.?!
    was found here..
    pistons look decent
    cylinders look good.. tops are dirty which is to be expected
    Super Moderator
    Spaz's Avatar
    ok little update.
    Put the car in the air... and went to town
    Pulled off turbo and found what I expected...
    oil everywhere between head and manifold
    Subframe and trans were next
    switched valve covers to protect my painted one
    Anyone elses wives help pull engines?!
    this oil pool always drove me nuts. Looks like just the sensor in the end...
    Anyone know what this white shit is?!
    I believe it's from the E85
    LONELY ENGINE BAY
    Premium Member boosted_teg's Avatar
    nb, canada
    that little thing is a water/coolant diverter.
    2001 Boosted Built k20a2 Billet BB 6766BB
    2013=579whp 406trq @ 24 psi c16
    10.87@137mph
    2014= 510whp 370trq @ 18psi pump gas
    2015= 7xx @ 30psi??
  9. #7
    Super Moderator
    Spaz's Avatar
    So I'm looking to go around 10.5:1 compression what are your guys thoughts?
    Quote Originally Posted by Spaz View Post
    That's a good ratio. A lot of ppl are running that or 11:1
  11. #9
    BoostedK20.com Founder
    BoostedK20's Avatar
    10.5 sounds good. Minimal difference between that and 11. What plugs will you be running?
    Just want to say that it's awesome you're so organized with your tear down. Takes experience to get that stuff down!
    Need parts for your k-series setup? Check out our eShop! Click Here
    For all your eShop support needs:BoostedK20.com eShop Support Forum
  12. #10
    Senior Member Spoolin_VTEC's Avatar
    US
    Dude, SO organized. I need to do this on my next build.
