Page 28 of 32 FirstFirst ... 1828 ... LastLast
Results 271 to 280 of 319
Thread: Spaz is Back and BOOSTED
  1. #271
    Well shortly I'll be making the 8 hour drive to Kentucky for Import Alliance. My car though has no AC as I pulled it for my tuck... I'm taking my GF this year and so we, yes I let her do this DIY with me, made a poor man's AC. They say on average it is good for around 6 hours. So I can easily make a quick stop at any gas station and buy more ice and keep it going.
    So here is what I'm using. 5 gallon bucket, 5 gallon styrofoam liner, 2" PVC Couplers (x3) 2" Hole Saw, Drill, Mini fan and silicone sealant.
    First off, make sure you cutter is same size and coupler
    Then cut out 3 holes in your bucket
    Test fit.. should be tight fit
    Now place your liner in the bucket and cut out the Styrofoam
    Now test fit that
    Take your silicone and go around all the piping pieces to a make a air tight seal
    Now trace out your fan onto the Styrofoam
    test fit fan
    Now cut smaller hole for fan to fit in top lid
    test fit and make adjustments as needed
    Boom you're done. I plan on running a frozen milk jug of water inside the styrofoam. But you can use anything you want. A bag of ice will work just fine. The milk jug will just be easier to contain the water once it melts. :thumbsup:
    I have a digital thermometer I will test this out on a hotter day. But we put it in the backseat and sat in the garage with it on and you could definitely tell a difference. Obviously not perfect like the factory AC but when you have none anything is better than nothing.
    Now test fit that
    test fit fan
    Lmfaooo. I saw this on Facebook. Dude make it a diy. I may do it too. #noACcrew.
  3. #273
    Senior Member SAX JONZ's Avatar
    Feb 2013
    Redneck engineering. Lol right on.
  4. #274
    My injectors are the downfall. They aren't performing correctly my tuner says. He definitely recommends me getting different injectors and a bigger better pump or run dual pumps.
    What injectors and fuel pump? Do you have a return?
    Now test fit that
    test fit fan
    That is awesome!
  5. #275
    Senior Member 02civic629's Avatar
    Mar 2014
    VA
    How are you gonna plug in the fan to the car?? and yes I might just make one of these for long hot trips #noACcrew
  6. #276
    That is awesome!
    I'm running 1000cc injectors and 255 walbro pump. I am also running a return line. I called Injector Dynamics turns out the injectors I bought are fake. So with what my tuner says they are probably not spraying as well as they should acting more like 800s than 1000s. I'll be swapping them out with 2000cc and a dual fuel pump setup.
    Quote Originally Posted by 02civic629 View Post
    They make the same fan with cigarette lighter plug but in this case I have a power inverter I am using for 12v
    Mar 2014
    VA
    Now all you need are some cheapo hoses so you can route the air to blow directly on you
  8. #278
    Feb 2013
    Fake?! Wth? That sucks.
  9. #279
    How did you tell they were fake? I have a feeling mine are.
  10. #280
    The ID injectors I bought used have an extra SN hand engraved into the injectors and when I had them cleaned and flow tested by ID they didn't tell me they were fake. Do yours have the extra SN?
