Results 111 to 120 of 159
Thread: Si Speed 317's 400whp Daily Driver
Threaded View
    Many of us go through tragic events in life, and family are the closest people to you during those events. They make you smile, laugh, and forget about the bad. I want to thank my 8thcivic family for wishing me the best and a speedy recovery since my accident in April of 2010.
    Also, my turbo build is dedicated to a fallen 8thcivic member, Tobie Cook (sh33t 0f p4p3r).
    RIP Tobie - You're always in our thoughts and prayers :bighug:
    For those of you who aren't aware, click here: http://www.8thcivic.com/forums/8thci...und-tobie.html
    Thank you to Supa Ninja (Neener), Soxfan143(Mike), BlueSi4(Oriol), and anyone else who has helped me get to where I am now. I know the tons of questions weren't easy, lol. :grouphug:
    __________________________________________________
    8.31.11 - 30R Teaser
    3k-7k, 6psi. Awesome. Redline pull video soon.
    SRT One-Off Top Mount Manifold, Downpipe, and Dumptube
    Before Heatcoating
    Drag Setup
    Nitto NT555R Drag Radials on the front - Looks mean as hell
    New wheels - Rota Grids 17x9
    8thcivicfest 2011
    v v When we first got there v v
    BoostedK20 Mini-Meet
    End of Winter Photoshoot
    3rd and 4th Gear Pulls, 2/10/11
    Update 2/21/11: Purpulicious Awesomeness
    Update 2/18/11: New Shoes
    New wheels, Stern 17x8.5 +35. Can't wait to install!
    Old Wheels:
    Update 2/7/11: GO-Power Suspension
    Winter Fotoshoot
    Winter Mode
    ClubRSX Meet 11-7-10
    Winter wheels. HFP Rear Lip and Side Skirts will be installed next week
    Parts Received:
    Engine Management: Hondata FlashPro
    Intercooler: CXR Single Sided 29x8x3.5 (Maintains OEM bumper support)
    Intercooler Piping: GReddy
    Motor Mounts: Injected OEM
    Blow Off Valve: HKS SSQV
    Boost Solenoid: MAC
    Injectors: FIC 1000cc, PnP Clips for FIC 1000cc
    Fuel Pump: Walbro 255lph
    Gauges: AEM Uego Wideband and GlowShift Boost
    Brakes: EBC F&R Blank Rotors, Hawk HPS Front Pads, Centric Heavy Duty Rear Pads, STOPTECH SS Front Brake Lines
    Manifold: One-off SRT Tubular Top Mount
    Turbo: GT3076R
    Wastegate: 38mm TiAL Sport
    Downpipe: 3" SRT
    Oil Return: TSI kit with ATP 5/8" barb oil return
    EVAP Check Valve: USPlastics
    Map Sensor: Hondata 4 bar
    Heat Reduction: 12" x 24" Reflect-A-Gold Foil
    Intake: 4" Custom
    Misc Turbo Parts: 14mm Banjo Bolt for coolant lines x2
    Gaskets: 5 Bolt discharge; T3 inlet, exhaust manifold, oil return
    Lines: Oil Feed(-3an Oil Inlet with .035 restrictor, -3an Braided Stainless Line, -3an to 1/8" NPT, 1/8" BSPT to 1/8" BSPT & NPT for oil pressure sensor)
    Exhaust: 3" Full Race
    Spark Plugs: NGK BKR9EIX
    Intake: 4 ply Silicone Coupler
    Heat Reduction: JetHot Coating on Manifold, Turbo hot side, and Downpipe
    Catch Can: Moroso Breather
    Hottness: HFP Side Skirts, Custom Purpul Valve Cover and Shocker, I <3 HATERS and Got Boost? Battery Tie Downs, HFP Rear Lip, Viper 5901 Alarm
    Suspension: GO-POWER Suspension; currently 8k front, 10k rear.
    On the way:
    Parts Remaining:
    Clutch: Stage 4 CompetitionClutch and OEM Throwout Bearing
    Link List
    Clutch: Competition Clutch Stage 4 - Strip Series 1620 Clutch Kit - Import DPS Online - Your Import and Sport Compact Performance Source - Free Shipping All Orders Over $100
    "when you add to car use coupon code "COMPK20" and it will drop it down to $325 with free shipping"
    Manifold Studs (OEM): Part 14 Honda Automotive Parts
    And the nuts: Part 7 Honda Automotive Parts
    Walbro 255lph Install: http://www.8thcivic.com/forums/force...-pump-diy.html
    Oil Feed Line
    -3an Oil Inlet fitting for GT28R with .035 restrictor built in: -3 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com
    -3an Braided Stainless Oil Feed Line: -03 Oil Feed Line, Braided Steel Line With female (flare/JIC/AN) swivel ends 24 INCHES long : atpturbo.com
    -3an to 1/8" NPT for Oil Sandwich Adapter: Straight 1/8" NPT to -3 AN : atpturbo.com
    Gaskets
    T25 Inlet Gasket: T25/GT25 Inlet Gasket : atpturbo.com
    5 bolt Downpipe Gasket: Gasket, 5-Bolt for Garrett T25 Flanged GT28/30R-WG Turbine Housings : atpturbo.com
    Turbo Misc:
    3" Intake Inlet Adapter: Inlet Adapter 3" racing , for GT28R and other 2 bolt Garrett Housings : atpturbo.com
    2" 3 bolt Outlet Adapter: 3 bolt outlet adapter - GT28R/GT25R/T25 Compressor, aluminum : atpturbo.com
    Wastegate Actuator 6-7psi: Wastegate Actuator 6-7 PSI Rating (GT28R style with integrated bracket) : atpturbo.com
    14mm Banjo Bolt for coolant lines x2: 14mm Banjo Fitting Set for coolant lines - 3/8" Barb : atpturbo.com
    Hondata 4 Bar: Xenocron Tuning: Hondata 4 Bar Throttle Body Mounted Complete Map Sensor, ***embled and Ready to Plug and Play on your B, D, H motor with a Throttle Body Mounted Map Sensor #[Hondata 4Bar]
    JAZ Catch Can: Xenocron Tuning - Jaz Products Overflow and Breather Tanks for Racing
    EVAP Check valve: 1/4" KynarŪ Standard Check Valves | U.S. Plastic Corp.
Tags for this Thread
