aLmk
Well the source for my wastegate is its own source straight from the comp housing. The only thing T'd into anything is the bov and it works fine. And it isn't that we can't figure it out. It did creep, then didn't, then did again. And I have no idea why it did either.
I really really really doubt the diaphragm has any damage. Have you ever changed a spring in a wastegate? You would have to try pretty hard to damage the diaphragm when doing that. As for the pressure source leaking that is amazingly unlikely as that's the same exact pressure source and fitting as it was before it went to the shop, in fact that wasn't even touched.
