Couple questions:
Someone told me at some point that you should store crank shafts standing up rather than lying down, is this true?
I'm thinking that I'd like to do a very mild build for this, manley turbo tuff rods, JE 10:1 pistons - 86.5mm, stock cams, stock valvetrain, APR head studs, stock bearings. If I go this route, would I be able to rev above 8600 if I use the rsx oil pump? I ask because I may want to rev higher at the track only and if I can using these parts and the rsx oil pump (since I have one of those) I will use the rsx oil pump, if not I'll stick with the stock oil pump, unless someone has a good reason not to.
What special tools will I need to assemble the motor? I know I'll need a piston ring compressor, what else though? Is it best to have a machine shop blue print the block and put the bearings in for you?
Also, since this was my first time doing this, I followed the service manual and when loosening the head bolts and girdle bolts it says to turn each bolt 1/3 turn and do it in a sequence so I did, my question is, once each bolt is loose enough that they are no longer torquing down on the head/girdle is it ok to just take them out quickly? Or should I maintain that 1/3 turn then next bolt and so on? It just takes a damn long time lol
