Full Race Geoff
whats up guys --
i dont have too much time today to go into a lot of detail, but i wanted to give you some info on boost creep. Sorry if it doesnt initially make a lot of sense, there is a lot to think about --
An engine works by pressure differentials. A pressure differential is when one side is high pressure, and the other side is low pressure, so gasses move from high pressure to low pressure. Think of a balloon, all the air inside is at high pressure, put a hole in the balloon and they all want to escape to low pressure (atmosphere).
Boost creep occurs when the wastegate is fully open, but the engine is still making more and more boost. This means that there is a pressure differential that is so low, the gasses would rather go thru the turbo than a completely open wastegate. Think about that for a second -- when you use our turbokits the gasses would rather spin the turbo then go out the wastegate . Ever hear someone describe a turbo car as "bottled up" or "that thing needs to breathe". You will never hear that about our kits. This low pressure is why our kits make so much more power and spool the turbos so much earlier.. Full-Race manifolds are designed SPECIFICALLY to operate at low backpressure levels... because they breathe really well. Inhale, compression, ignition, exhale ->spin turbo fast. This is how we make so much power so easily, and on stock engines, Full-Race kits breathe into and out of the turbo better
You want to have the boost control of a log manifold? that is really easy, put the restrictor in your thermal exhaust. change to a 2.5" downpipe, put on a tiny turbine housing - litterally BOTTLE it up. Of course then you will be makes 70-80+whp LESS and dyno like a cast manifold setup like greddy or hks would make... have to set vtec later... lots of other issues. If you come to full-race you get a package that will outperform any other setup. If you want ultra-low boost all you have to do is order the kit with the upgrade to a 60mm wastegate, this is simply special order so it takes a little longer, but its a great solution. We do the same thing on all our B series headers for customers that boost creep.
if you have a 44mm wastegate and need better boost control, the small yellow spring is so light that it MUST be hooked up to an electronic boost controller or the turbo will be very lazy. The solution for this is to use an electronic boost controller hooked up to the TOP port (the side that says tial on it). The wastegate's side port should go to the intake manifold
regardless of wastegate choice, I strongly recommend installing a thicker head gasket (to lower compression) and ARP head studs. This allows you to boost comfortably higher and can save a lot of time and money since you really dont NEED to build the motor... but the 44mm is really better for 99% of applications anyway.
