Results 191 to 193 of 193
Thread: New guy here! 600whp or bust build
Threaded View
    Senior Member 1SLOWFG2's Avatar
    Feb 2012
    I've been on the forum for a bit just have not posted a whole lot... I went 10 months on my boost Junkyz kit and stock motor and made 462/300 on 15psi . We are now in the process of doing a sidewinder kit with a comp ct4-6062 an see what kind of power it will make. Ill be running on a stock block and pump gas for the time being , but building my spare motor for big numbers. Ill post a few pictures of the car and I will try to post more as the build progresses but I'm pretty busy right now so stick with me.
    List of mods
    -one off Boost Junkyz front mount 2 piece turbo manifold
    -Boost Junkyz 3" 2 piece downpipe
    -Boost Junkyz vertical flow same side intercooler
    -Boost Junkyz wrinkle black powdercoated charge piping
    Boost Junkyz catch can/ coolant reservoir
    -Comp Turbo ct4-6062 triplex ceramic ball bearing turbo
    -2 Tial Mvs 38mm wastegates Black
    -Tial Q black blow off valve
    - [MENTION=789]VitViper[/MENTION] 4 port boost control solenoid
    -aluminum v-band charge piping couplers
    -Boost Junkyz hand port and polished intake manifold powdercoated wrinkle black
    -tsx hand ported and polished throttle body powdercoated wrinkle black
    -Injector Dynamics 1000cc injectors
    -Karcepts black fuel rail
    -Hondata 4 bar map sensor
    -Full-race 3" cat back exhaust full v-band
    -Aem digital wideband and boost gauges
    -xlr8 dual gauge pod
    -Hondata flashpro
    -Hondata traction control
    - [MENTION=789]VitViper[/MENTION] tuned
    -custom powdercoated vented valve cover
    -all vacuum lines , catch can lines, fuel lines in black AN fittings and black SS nylon lines
    -Walbro 255lph fuel pump
    -varrstoen es 2.2.0 17x9+30 wheels on 245/40/17 Bridgestone tires
    -Varrstoen neo chrome open ended lug nuts
    -skunk2 coilovers
    -skunk2 v2 rear camber arms
    -pink beaks rear lower tie bar w/ BOOSTED BITCHES sticker
    -Hybrid racing full replacement short shifter
    -hybrid racing cable bushings
    -mtec shift spring
    -competition clutch stage 4 clutch
    -hasport full replacement mounts
    -09 front end conversion
    -s2000 push button start
    -dual projector retrofit headlights
    This should be a fun build !
    How the garage looks now getting the kit ready to ship out
    I'm gonna miss this manifold we had lots of good time together lol
    Too much shit in here
