Page 25 of 30 FirstFirst ... 1525 ... LastLast
Results 241 to 250 of 291
Thread: [ysosrs] dc2r k20 turbo
  1. #241
    Newbie djtooon's Avatar
    Feb 2014
    NJ
    car looks amazing!!
  2. #242
    Nov 2012
    After a 1 month holiday away in Vietnam, it's wrenching time!
    Started by removing the dash to finish off the brake tuck, install the milspec harness and a tidy up in general.
    I bought some more hardware for the car along with the downstar firewall plug kit. I must say, they look really good.
    On the inside
    Back to the drawing board again....
    Picked up another daily car, needs some good tlc though.
  3. #243
    Nov 2012
    new exedy oem replacement clutch kit and the k-tuned shifter for the beater.
    Mounted on the griffin rad, the top rad hose unfortunately kinks, cutting it was the only option.
  4. #244
    Nice updates and pictures! Everyone gets great pictures on this forum. I love it, technology is such a great thing.
    How did the beater installs go?
  5. #245
    Nov 2012
    Hey guys, Just strarted the car with a base map off the kmanager and car idles quite rough.
    Can anyone chime in with a modified map on the safest setting possible?
    Jdm k20a motor
    5858 dbb
    rbc
    stock tb
    id1000
    even after setting in the dead times etc, it still idles pretty rough.
    Thanks boostedk20 community =]
  6. #246
    Quote Originally Posted by mnc1408 View Post
    Jdm k20a motor
    5858 dbb
    rbc
    stock tb
    id1000
    I have no clue. But these guys likely do [MENTION=158]E-Tunez[/MENTION] [MENTION=974]MercRacing[/MENTION] [MENTION=56]PetefromtheStreets[/MENTION] [MENTION=40]monjarassi[/MENTION] [MENTION=28]Spaz[/MENTION]
  7. #247
    Quote Originally Posted by Spoolin_VTEC View Post
    I would most likely need to see the map to see what could be wrong. And a datalog
  8. #248
    [MENTION=334]mnc1408[/MENTION]
  9. #249
    Nov 2011
    No problem, we don't usually give freebies, but seeing we havn't done anything for BoostedK for awhile, this one is on the house. Its just a basemap of course, so will require more work for sure. Had tuned one of these on the rollers last year, near identical build so should be close, reset some parameters for safety. Recommend 4 bar sensor, be sure to calibrate TPS. As always, all maps are for offroad use only, there are no mechanical gauruntees, please review parameters before uploading, please check our site for the legal disclaimer, etc.
    Etunez custom tune for: Boosted K20
    Type: Offroad use only.
    Car: K20 PRB
    Modifications:
    SD Based intake
    5858 Turbo
    ID 1000cc injectors, standard latency.
    Assumed 48psi +/- 5psi fuel pressure assumed.
    Free flowing Exhaust
    Fuel: 93 Octane 10%E assumed.
    Elevation: 500ft ASL assumed.
    Rev1: Custom fueling, ignition and VTC for a PRB K20 turbo build, Assumed stock MAP sensor, recommend 4 bar.
    Attached Files Attached Files
  10. #250
    Nov 2012
    Thank you so much boys,
    I will upload the courtesy map supplied by e tunez with adjusted parameters. Will post up a few minute data log tomorrow.
    Thanks again to the community [MENTION=1]BoostedK20[/MENTION].
