Went over to my mums house to check up on the motor after that horrible windy event we had in Melbourne not long ago. Threw on the k-tuned breather while I was at it.
I probably won't be using this rocker cover though. Next rocker cover I'll be shaving the OEM breather port and will be welding on a single -16an fitting preferably to the back near the firewall for my custom catch can setup
Was a little bored last night so I decided to work on the Hasport Mounts, started by removing the old inserts. Next will be a good wet sanding session followed by buffing with metal polish and finally reassembling everything with the new 88a inserts
