Got my Hardrace bushings pressed in by the boys at ZEDS. I will be giving these arms a good clean up before it goes back together with the car. I will also be applying some paint to the bushings metal surface as they are known to rust.
Ordered a few things from JHPUSA, sadly it got stuck at customs for a good 3 weeks.
Hasport replacement rear engine mount bracket and some new 88a bushing inserts.
Skunk 2 replacement ball joints for the front upper camber arms.
K-Tuned shifter cable heat shield tubing. (bought 2 but only 1 pictured)
K-Tuned Rocker cover breather filter.
K-Tuned coolant temp sensor and the RHD clutch line.
K-Tuned shifter cable bushings and a high flow fuel filter (8an) rated to 300-500hp.
K-Tuned A/C & P/S eliminator kit.
Bolt Boys hardware.
* Engine bay kit (dc2/r)
* Engine mount kit
* K-Series engine kit
* upper control arms and strut kit
JHPUSA have some really nice looking stickers. Thanks again to Jeff @ JHPUSA for looking after me.
