							Current Modification List to date are -
 Engine
 K24A3
 * BluePrint Stage 2+ BILLET Camshafts
 * BluePrint Valvetrain
 * 50 Degree VTC
 * Hasport  Engine Mounts.
 * Hondata Intake Manifold Gasket
 * RBC Intake Manifold Match Ported to 70mm
 * S90 70mm Throttle Body + Adapter
 * K-Tuned Ram Intake + Velocity Stacker
 * K-Tuned V2 TPS Sensor
 * K-Tuned Coilpack Cover
 * K-Tuned Valve Cover Breather Filter
 * DTR/SSR K-swap Header
 * 3'' 100cell cat
 * 3'' exhaust system + 2 vibrant resonator + Varex chambered muffler
 * Magnetic Oil + Transmission Sump Bolts
 * Mugen Oil Cap
 * Deka light weight Race Battery
 * Hybrid Racing Ground Wiring Kit
 Engine Management
 * Hondata K Pro tuned by BYP @ 157.2 kw atw.
 Transmission
 * Jdm Ep3r Gearbox
 * Exedy Heavy Duty Clutch
 * Oem Lightweight Flywheel
 * Oem LSD
 * K-Tuned Billet Shifter Box
 * Karcepts Shifter box mounting plate
 * Hybrid Racing Gear Knob
 Fuel Setup
 * RDX 410cc Injectors + Injector Clips
 * Walbro 255LPH Intank Fuel Pump
 * K-Tuned Fuel Rail
 * K-Tuned Fuel Pressure Gauge
 * K-Tuned Fuel Pressure Regulator
 * K-Tuned Slimline Fuel Filter
 * K-Tuned Fuel Lines + Fittings
 Cooling
 * K-Tuned Half Size Radiator
 * K-Tuned Radiator Hoses
 * K-Tuned Swivel Neck Thermostat (185F)
 * Fan Switch Via K-Pro Set At 195F
 * 12'' Slimline Radiator fan
 Suspension
 * Zeal Function X coilovers
 * Skunk 2 Front Camber Arms
 * Unknown Rear Camber Arms
 * Full Race Traction Bar
 Chassis Reinforcement
 * Edelbrock 3 point front strut tower brace
 * Miracle X bar
 * Beaks ( Gold ) Lower Tie Bar
 Brakes
 * Spoon Twin Block Brake Calipers
 * Apexi GT Spec Front Brake Pads
 * Project Mu Max 500 Rear Brake Pads
 * App Braided Brake Lines
 Wheels & Tyres
 * Enkei Racing S 16x8 +32 x8
 * Advan AD07 225-45-16
 Interior
 * Driver + Passenger Recaro sr3 nylon seat covers.
 * Apexi RSM + G Sensor (Black Edition)
 * Jdm Sun Visors
 * Jdm Rear Seat Belt Buckle
 * Jdm Red Stich boot
 Exterior
 * 98 Spec Jdm Front End Conversion
 * BYS Front Bar
 * OEM Optional Rear Pods
 * OEM Optional Side Skirts
 * OEM Window Visors
 * Shark Attack 2 Antenna ( S2000 Rep)
 * Rays Extended red wheel nuts
 Hopefully I'll do well for my first time out. Got a feeling my tyres will be a let down.
 Any tips on wheel alignment specs to maximize my potential?
							(Technical issues with bandwidth limits)
