Page 1 of 4 1 ... LastLast
Results 1 to 10 of 32
Thread: marsman328's Sheepey Built DC5 Build
    Newbie marsman328's Avatar
    Greetings
    Some of you might know me from ClubRSX (hi)! For those who don't know me, hello. I've been on ClubRSX for years, decided i would finally post up on here.
    Enjoy!
    Sponsors:
    • Continental Tire
    • Seibon Carbon Fiber
    • NeoChromeParts.com
    • DICE Motorsports
    • Sheepey Built
    Modification List:
    Interior:
    • OEM DC5 Type-R Recaro Seats, Black suede w/ red stitch
    • OEM DC5 Type-R Rear Suede Seats
    • OEM DC5 Type-R Honda Badges
    • Autopower 4point roll-bar (custom fitted through rear panels)
    • Full black interior
    • Custom black suede headliner
    • S2000 Cluster retrofit
    • S2000 push start button with custom carbon panel
    • Nardi 330mm black/red stitch steering wheel
    • NRG steering wheel release/short hub
    • Crow Enterprises Black 3” 6 point racing harnesses
    • Pioneer Navigation
    • JL Audio 4ch/mono Amplifiers & speaker/12”sub
    • Generic C-pillar Bar
    • Hybrid Racing RSX Shifter Box
    • Skunk2 Weighted Knob
    Exteror/Body:
    • Custom pearl white color (BMW Frost/Lexus Pearl)
    • Shaved engine bay, with blue flake
    • Seibon Carbon Fiber TS Style Hood, Paint matched, showing carbon in vents
    • Seibon Carbon Fiber TR Style Spoiler, sides of spoiler paint matched
    • OEM A-Spec Front lip
    • Type R Front Bumper
    • Mugen Style VIS Side Skirts
    • Mugen Style VIS Rear Lip (custom molded to rear bumper)
    • Custom mounted flush back up camera in 3rd brake light
    • OEM DC5 Type R Black Housing HID Headlights
    • Password JDM Bumper Quick Release Fasteners (Custom NeoChrome Blue)
    • PLX DM-100 Touch & DM-6 (Two) Gauges
    • Ortiz Custom Pods
    Dual Center Console Gauge Mount & Single Left Air Vent Mount
    Brakes/Suspension:
    • AP Racing 4 Piston BBK 330mm (Custom NeoChrome Blue Caliper and Hat)
    • Function&Form TypeII Coilovers
    • OEM DC5 Type R Sway Bars/Control arms
    Wheels/Tires:
    • Rays Gram Light 57dr Semi-Gloss Black
    18X9.5 +22/18X9.5 +38
    • Continental Tires: Extreme Contact DW
    235/40/18 (front) 225/40/18 (rear)
    • Project Kics R40 Iconix Locking Lug Nuts (NeoChrome w/ black centers)
    Motor/Performance:
    • Hondata K-Pro
    • RBC Intake Manifold (CNS Custom Works Shaved and Polished)
    • Golden Eagle Fuel Rail
    • K-Tuned A/C P/S Delete
    • Tucked Clutch Line
    • Relocated Fuse Box
    • Relocated Battery
    • Wireworx Non-MilSpec Tucked Engine Harness
    • Custom ABS Delete Tucked Brake Line Kit (Encore Kit)
    • Innovative 75a Billet Mounts w/ steel front mount
    • Valve Cover (Custom NeoChrome Blue) with custom All-In Fab Catch Can
    • Innovative 75a Billet Mounts (Custom NeoChrome Blue)
    • Competech Titanium Front Strut Bar (mounts Custom NeoChrome Blue)
    • Downstar Dress Up Washers and bolts (Washers Custom NeoChrome Blue)
    • Sheepey Built Turbo Kit,
    Black thermal coated Manifold, DP, Exhaust Housing
    Precision 6062 Gen 2 Ball Bearing Turbo
    • Tial 60mm Wastegate/50mm Blow off Valve (Clear Anodized)
    • RyWire Tucked Radiator w/ -16 AN fittings
    Jegs -16 AN Blue/Silver Fittings
    Russell Black Nylon Braided Hose w/ blue accents
    • K24a2 Block
    • Weisco 87.5mm Pistons 8.8:1
    • Eagle H-Beam Rods
    • OEM Honda Bearings
    • Supertech Valves(flat face)/Springs/Retainers
    • Black powdered OEM Throttle Body/K-Tuned spacer
    • Skunk2 Low profile Valve Cover hardware
    • Walbro 400lph Fuel Pump
    • Injector Dynamics 1000cc Injectors
    • Aeromotive Fuel Pressure Regulator
    • Jegs Blue/Silver –AN fittings (-8an Feed, -6an Return)
    • Russell Black Nylon Braided Hose w/ blue accents (-8an Feed, -6an Return)
    • Competition Clutch Stage 4
    • Fluidampr Crank Damper
    • K-Tuned Oval 3” Catback Exhaust
    • K-Tuned K20 Upper coolant housing with filler neck (-16 an fitting)
    • K-Tuned K-Series Lower swivel housing with (-16 an & recirculation fitting)
    • K-Tuned Coolant Cap
    • K-Tuned Billet Throttle Cable/Bracket
    • K-Tuned Billet Transmission Bracket
    • K-Tuned Coil Pack Cover
    The Engine Bay Shave:
    The Motor:
    The Sheepey Built Turbo Setup:
    How she sat at SEMA 2015: (yes, i know there is no radiator lol)
    Picked the car up at the body shop on Thursday Oct 29,
    Dropped the motor in Friday Oct 30,
    Drove to Perris, CA to Sheepey Built and was at the shop 11pm on Oct 31st
    Left Sheepey at next afternoon at 4pm after pulling an all nighter.
    Rolled into SEMA Monday Nov 1st.
    Was a very sped up process to get the car ready for that event, but there is still stuff to do before the car will be ready to run.
    The loose ends I need to tie up before she will run are: the Fuel system, the Brake lines, and RyWire tucked radiator and 16 an hoses all have to be installed.
    Once that is all together and tight, I will post another update!
    Hopefully i will have some numbers to share with you guys within the next few weeks!
    Thank to everyone who has been following my build over the years, i finally made it! lol
    Had a little time over the thanksgiving holiday weekend to put in a few hours.
    Ran the extended fuse box power harness thru a hidden grommet behind the passenger fender and up to the passenger air bag area. mounting the engine bay fuse box there!
    Started the extension process for the fuse box, calculated that I will need 183' of 18 gauge wire, and 39 feet of 12 gauge.
    I should get the wire soon so i can finish the harness. Going to be solder and shrinking all connections.
    Also, re-loomed and shrinked the charge harness. All plugged connections are already built into the engine wiring harness, so only connections for the charge are 8gauge from battery, for alternator and starter.
    Found a couple more pictures from the engine build.
    My builder specialized in k-series motor and heads and he added an oil mod to the head to better lubricate the cam journals.
    There is a port on the side of the head that i will run the oil feed line to.
    He tapped a custom oil feed port by the temp sensor.
    He also tapped a second port on the right side (not shown), and plugged it just in case i want to add an additional sensor.
    Lastly, a picture of the brake line tuck kit by CRSX Member EncoreDC5!! Super clean kit by the way lol
    (reserved)
    (reserved)
    Hell of a build! Welcome to the forum. Congratulations on SEMA man, very cool! Loving the oil tap for the cams.
    Looking forward to the rest of this build!
    Beautiful build! Big congratulations on making it to SEMA! Oil tap is very interesting, I've never seen that before! Surely looking forward to the rest of your build. Brake tuck looks promising! Wiring looks like hell, but good for you for tackling it!
    I appreciate you posting up and sharing with us! I will surely be keeping track of your build! What is your power goal?
    Thanks guys!
    Power goal is 600whp on this setup.
    I will probably get a more conservative street tune for now since I am still running stock trans and axles....
    I don't want to completely ruin the trans yet lol
    The wiring I'm not looking forward to finishing, but it should turn out all good in the end!!
    I do plan to have the car running and tuned by mid January!! ill be posting more updates as they come
    Jan 2014
    Corpus Christi TX
    33
    Quote Originally Posted by marsman328 View Post
    niice spot for fusebox
    Thanks guys!
    I like the goals and conservative tune part. Reality is, the trans can go at any time. Are you running an LSD? IIRC the DC5's didn't come with one, just the Si's? I'm with [MENTION=1]BoostedK20[/MENTION] on that one, wiring is one thing I hated doing on my car. Even the basic stuff, it's just not my forte. I'm definitely in for those upcoming updates! As for your build running my mid-Jan, do you think anything will possible limit you? I know there is always unforeseen stuff that comes up, but I'm JW.
    Hey man, I know it can be annoying but I think snapping a few pics while doing things could really help people out that want to do things but don't have the money to pay a shop. They can DIY and learn at the same time. I'm not a K-series guy but it would be cool to those in need. Maybe even those that aren't K-series related like how to do basic wiring shit. Idk, I'm just thinking it could be helpful lol. Cheers either way, don't wanna put you on the spot. I just remember when I was doing my build a lot of people PM'd me asking about how to do things or how I did things. I never took any pictures because I had a desktop computer and still use a flip phone. I could draw a better picture than my phone can take - and I can't draw for shit.
    Quote Originally Posted by Shanket View Post
    Thanks man.
    Quote Originally Posted by Spoolin_VTEC View Post
    Money is the only thing holding me back at this point to finish. I've spent..... $(a large sum of money)... just in the past 3 months to get it ready for SEMA, and i have a couple thousand left to spend, so I'm just saving my pennies to finish up by the end of the year. (tune, brake booster delete kit, fluids, misc parts, misc fittings)
    i am the type of guy that takes pictures of everything lol
    i have a lot of pictures that i have not posted yet, i always take a lot of pictures, so ill be posting more updates as the build slowly gets finished.
