Results 1 to 10 of 291
Thread: [ysosrs] dc2r k20 turbo
    Nov 2012
    I have a k20a2 long motor at the shop getting built but because it cost quite a bit for what I'm after, I will be picking up a Jdm K20a long motor to use for now this Sunday.
    There isn't much left to buy for the car.
    *brake tuck (chasebay)
    *fuel lines (k-tuned)
    *boost solenoid (hondata)
    *vacuum box
    *I have an exhaust already but just need to modify it to fit
    *Lsd for the 5 speed dc5 box and "maybe" switch out the 4.3 fd for a 4.7 (not sure if the 5 speed 4.3 is too long or not)
    the rest is just doing things like powder coating a few things, buying the smaller things to make it all work.
    I'm aiming to have the motor in by the end of this month give or take a week.
    Quote Originally Posted by mnc1408 View Post
    *vacuum box
    Is the car going to be turbo'd?
    Here are your speeds for you to look at.
    Nov 2012
    The stock Jdm k20a will be boosted. I might throw in a new headgasket and arp head studs since I have a spare set.
    With the current turbo I'll be using, I plan to run around 9-12psi. Hopefully that would be good for 350hp max.
    The question is, do you guys reckon the gear ratio is too long with the 4.3fd?
    Michael
