Results 1 to 10 of 349
Thread: LGIndustries 67mm Street/Strip - Build
    Junior Member dkpr87's Avatar
    Feb 2013
    All good now tho. Woooot
    Yessir!!!! and now with that CNC goodness from MercRacing it should work even better :-)
    Quote Originally Posted by dkpr87 View Post
    What size tb do you have?
    Feb 2013
    Skunk2 90mm
    You?
    Skunk2 90mm
    You?
    Fuuuuuuck lol. I'm running a 74mm tb
    Feb 2013
    Bruh..... Sell that manifold and get something for a 90 ;-)
    Do this and your journey to the dark side will be complete
    You get the new one?!
    Feb 2013
    I'm still on stock TB lol
    Sent from my SM-G900T using Tapatalk
    Daaaaaaaang #TheStruggleIsReal
    Just got the plate for my Skunk2 90mm to help the idle :-)
    Awesome! Post a review for sure, with pics of course!
    Struggle is sooo real. Although, I had my RBC IM ported and polished, all vac ports closed and relocated to the bottom, and the inlet was ported to the OEM TB diameter. So it worked out well lol.
    Maybe in the future if I tinker with the car more, I'll add a 1xx TB. For now, stocker does the trick.
    Feb 2013
    Will do man!! the 90 is probably the biggest i'd go for a streetable use, but if this helps the bigger TBs i couldn't imagine it not helping some even larger ones too!
    Once the car is running again, i'll definitely post clips and everything!
Tags for this Thread
