I figured I'd make a thread of how I'll be setting up my fuel return. I purchased an already setup fuel cage for a return and full Stainless Steel (SS) -6an return line with SS Gojin 10 micron filter from aLmk, which was from ZeroCool, from [MENTION=109]Str8JDM[/MENTION], from Supa Ninja. Regardless of my whored out return setup, I'll be installing this with all new fittings and details. On to the pics:
This process will be taking the -6an SS line you see here and making this my feed line to the fuel rail. This will connect to the fuel rail on the passenger side of the car. I will be using the OEM feed line (hard line) as my return line. So I'll need a -8an male to -6an male to attach my AEM FPR (Fuel Pressure Regulator) to my fuel rail on the return side. I'll need an FPG (Fuel Pressure Gauge) for the front of the FPR, a -6an plug for the opposite side of the FPR, and a 90* -6an fitting for the bottom as the return.
On top of that, I'll be replacing the oem feed line from the firewall to the FPR with 2' of SS -6an line for aesthetic purposes. In a bit, I'll post up the complete drawing to make this a bit easier to grasp and understand. I will keep this updated as I go.
