trying to find it but on CRSX there was a manifold that was designed more for wastegate than turbo. Was a sick manifold.
I think it's the AFI manifold. The manifold Vit has on his black civic is also designed like that. Maybe he can post a picture here [MENTION=789]VitViper[/MENTION]
I agree with Almk, i am not certain where you read that you can reduce spring pressure but i also do not believe it is possible. Essentially you can't run a boost pressure lower than the spring pressure. A boost controller is only used to increase the total boost you want to run but adding pressure to the top of the WG. Would be beneficial if there was a way to reduce it but with the range a 4 port can operate in, just running a lower psi spring is also a reasonable option.
I think a 44mm wg is perfect for almost every application on this site. some people run twin scrolls and 2 44's might even be overkill but when it comes to preventing creep overkill is best lol. A 60mm wg unless your running some 800hp monster is unnecessary.
I like all of what you said, but in a way a high horsepower build can probably be just fine on a small gate, since it never really needs to run low boost anyways, who cares if most of the exhaust can't go out the gate when you need to make 30+ psi
I didn't read it anywhere apparently I was given the wrong info or misunderstood the guy that I was discussing it with last week at Cecil .As I said this is my first time exploring with 3 and 4 ports but you can bet when I'm done I'll know it well and have it perfected .I'll be making the change to reduce the amount of boost I can run if it means changing my wg springs then that's what I'm gonna do as I'd like to lower it to a few lbs in first and second on the street so I don't have to back pedal so much .I do indeed love the twin 44 mvrs they control boost so good up top it holds rock steady and you know I'm always one for overkill lol
Ya I would put the 3 psi spring in both your mvrs and use a single 4 port (unless using 2 3 ports is better, which I doubt it is, but I don't know for sure) as this will allow you to run as much boost as you'll ever want/need in the higher gears, but should make just about 3 psi on wastegate pressure.
Quote Originally Posted by 1JZ_Type-S View Post
If I change out my spring, I assume I'll need a new tune, correct? Due to the variation of boost pressures at different rpm
Who is your tuner? If the tune was done correctly, it really shouldn't need to be retuned. I mean turbos are not superchargers, they make boost at all different kinds of rpms since it is load based. So your tune should have the fuel compensation necessary for a lower boost level.
10 pound. I've only creeped a handful of times with it. My confliction is that I'm running a journal bearing turbo, so I need the wastegate to open as late as possible to allow for the quickest spool
What are you using for tuning? If you have k-pro or flashpro you can forget about this old school thought. With the quick spool feature hondata now has, a 4 port solenoid will hold your wastegate shut even more effectively than a larger spring would, ie it will keep a 3 psi spring gate shut till 3 psi comes and you will see much quicker spool because of it. Oddly enough just posted this in another thread, but Vit a while back showed a 1200 rpm improvement in spool time on a GTX3076 just by turning on quick spool.
