snizzletoff
I agree with Almk, i am not certain where you read that you can reduce spring pressure but i also do not believe it is possible. Essentially you can't run a boost pressure lower than the spring pressure. A boost controller is only used to increase the total boost you want to run but adding pressure to the top of the WG. Would be beneficial if there was a way to reduce it but with the range a 4 port can operate in, just running a lower psi spring is also a reasonable option.
I think a 44mm wg is perfect for almost every application on this site. some people run twin scrolls and 2 44's might even be overkill but when it comes to preventing creep overkill is best lol. A 60mm wg unless your running some 800hp monster is unnecessary.
