Results 1 to 10 of 17
Thread: Throttle body options
    Mar 2013
    Bowling green ky
    Ok guys I have a question. I have heard that the skunk 2 throttle body throws cel's and has a rough idle. I have heard of people putting the Acura Mdx and tl type s throttle bodies on the 8th gen civic si's. Comments, concerns, suggestions?
    I have done the TL on an 8th gen myself. No quality and performance can beat OEM when that's an option. I know that the DBW is a real beast to work with.
    Senior Member
    I am about to post the 72mm skunk2 for the k series.
    Senior Member 1SLOWFG2's Avatar
    Feb 2012
    I'm running a tsx and it's a bolt on process, though I would like the j37tb because oem is best . The skunk2 needs to be calibrated and it can be a pain !
    Quote Originally Posted by Lilwhit14 View Post
    I haven't found out the answer yet, but it always seems that OEM is the best if you can choose that route. The Research and Development, let alone the standards for their products are typically much higher than any aftermarket company because of the wide range of the possible conditions the product(s) will undergo. I have yet to figure out the best TB option since I'm running the stock 07 Si TB. But these guys will take care of you and let you know what's best. I'm in for info!
    Mar 2013
    Bowling green ky
    What did you have to do for the TL throttle body? Was it a direct fitment? What size is it?
    Mar 2013
    Bowling green ky
    Was it a direct fitment? What size?
    Mar 2013
    Bowling green ky
    Quote Originally Posted by My07si View Post
    What's the j37tb off of?
    Comes off a Acura ZDX. I saw them on k20a.org for $200 shipped. Requires an adapter which P2R sells.
    Inlet-78mm
    Outlet-70mm
    Feb 2012
    Inlet-78mm
    Outlet-70mm
    $200 shipped for real? Damn I need to get on it !
