This.
I plugged my IM on that side bc I didn't need the vacuum source. Remove the pcv valve, stick something in it and 'punch' out the internals. Re-install and connect to catch can. Now, you can have all the lines go to the driver side, or have them go to the pass side. If you're having the top-most port on the drivers side of the vc closed, then i'd say the passenger side. What ports will you be using from the vc, just the two you will be adding or the oem one as well?
