Do not do this Mod. It does not increase your tension. Just helps you install the wrong belt and create bigger problems later.
If you are going past the stop there is little spring load to help with proper belt tension.
If you are not going to have an SC I guess it does not matter as much, but alternator may slip often unnoticeably.
